InfluxDB on resin.io
Kimmo Huoman is an electronic engineering student and employee of Lappeenranta University of Technology. His main interest is home automation and embedded Linux systems in general.
What is InfluxDB?
In short, InfluxDB is a time-series database, designed to handle large amounts of numeric data.
What makes InfluxDB special when compared to many other time series databases, is that it doesn't have any external dependencies. This makes it fairly easy to deploy as there isn't much to install and setup. Just compile the sources or use the provided packages.
With version 0.11 InfluxDB started to provide official packages for armhf, which makes it possible to run the database on many embedded Linux boards. This, of course, makes one wonder if it's possible to run it on Raspberry Pi, and especially through resin.io...
Why InfluxDB?
The issue with running databases on embedded hardware is most commonly the performance, especially when handling large amounts of data. In the past, I've used anything from PostgreSQL to CSV files to save measurement data. This is however quite problematic when logging for long periods of time (most of my systems have been running for months, some for years). Typically values are logged once per minute from multiple sources.
The main issue is not saving the data but getting the data out in a usable form. With CSV files, I've done various custom solutions, including averaging the data from one file to a new one, just to get the amount of data to a more reasonable level.
With SQL, the issue typically is that it's fairly slow and averaging the data to a more reasonable amount is quite difficult. I've even used different tables for different time ranges, with monthly data averaged to one hour et cetera. After this, I've removed the time range from the original data.
My main goal with InfluxDB is to have the database doing the averaging for me, without the need for removing any of the original data. From my previous experiences InfluxDB seems to have very well optimized algorithms and a fairly simple query language.
One might wonder why I bother saving the data on the device in the first place? The main reason for saving the data to the device instead of the cloud is that I want all the functionality of my applications even when offline. Typically the devices I develop and use are used in remote locations, where 3G / 4G coverage may be unreliable. To be sure of the correct functionality, I want the data logged constantly. This would require some sort of logging on the device anyways, so why not store all the data on the device...
Another reason is also partly related to the 3G connectivity. My main use-case is home automation, and this of course means that the system is also (mainly) used in the internal network. Fetching the data from a remote server would be slow, and sometimes impossible.
Setting up
Setting up the Docker image was fairly straightforward, in essence, the Dockerfile is just fetching the ready-made packages for armhf, installing, and configuring them. The only change I made to the configuration was to move all storage to the /data partition, to preserve it between boots.
The project uses the Python-image as a base, as the measurement script is written in Python. Luckily InfluxDB also has Python-library available, making the logging fairly straightforward. It should however, be noted, that the Python-library doesn't seem to officially support 0.11 yet...
The measurement script reads 9 values from the board. The values are read ~once per second and written to the database. The values are:
  • load averages: 1, 5 and 15 minutes
  • memory: total, available, and percentage used
  • disk usage for /data: total, used, and free
Once both the measurement script and the database are setup, the next thing is to start them and most important of all, keep them running. At first, the systemd -script included in the InfluxDB package was used, which proved problematic.
The main issue was that the database was moved to /data, which of course the influxdb user doesn't have rights to, at least when specifically defining them. The rights were given in the start.sh, but this was run after the database was started, leading to errors. I couldn't bother messing with it and moved on to supervisord instead, as I've used it in the past with great success...
After the supervisor configurations were setup, everything worked flawlessly. The monitoring script does fail a couple of times before the database has started. Other than that, everything just worked.
Performance
As noted before, the issue is not saving the data but getting the data out. For testing this a small Python-script was developed which fetches different amounts of data, averaging it to different time periods. These tests were run after a sufficient amount of data was collected, roughly 3 million measurements.
The tests were run on two different boards, Raspberry Pi 1 Model B+ and ODROID-C1, as I happened to have them available.
To make the tests fair both hardware used the same memory card with the same Dockerfile.template. The database was backed up before changing the board and restored once the other board was provisioned. To minimise the random effects, the tests were run four times on both boards. Both boards also used the same WiFi -dongle for connectivity, as the test-script was run on my laptop.
To get an idea of the performance, the stored values were fetched using four different time ranges: 2, 6, 12, and 24 hours. A single measurement contains ~3600 measurements per hour. My main interest isn't in the raw values though. Instead, I'm more interested in fetching mean values, especially when considering longer periods of time.
The main test is aggregating the mean values from the raw values. In order to achieve that, averages for 1 minute and 1 hour were calculated from the raw measurement points. Again, multiple aggregation functions are included in the InfluxDB query language. The function used in the test is MEAN, but from my experience all the functions seem to have quite similar performance.
The first two columns in the following tables show the fetched time range and the number of raw points in that time range. The three remaining columns represent the execution time of the query in milliseconds. The times were logged for fetching the raw points, 1 minute mean values, and 1 hour mean values. So with 1 minute mean, there's 60 values per hour.
The mean times (in milliseconds) for fetching load averages from RPi B+:
Time range Number of raw points Raw [ms] 1m mean [ms] 1h mean [ms]
2 hours ~7200 3676 161 98
6 hours ~21600 9630 662 175
12 hours ~43200 20073 679 362
24 hours ~86400 30674 1120 1145
The mean times (in milliseconds) for fetching load averages from ODROID-C1:
2 hours ~7200 843 57 40
6 hours ~21600 1804 91 48
12 hours ~43200 3760 239 87
24 hours ~86400 6025 339 124
Overall the performance is fairly good even on the Raspberry Pi. With ODROID it's exceptional! The ODROID performs the queries in ~10-30 percent of the time used by the Raspberry Pi. Furthermore, the times are more constant on the ODROID,
which might be because of the multi-core processor. With multiple cores, different background tasks don't slow down the processing that much, leading to a more consistent experience.
The results were consistent also on the memory test. However running two queries with the same request didn't seem consistent for whatever reason. Sometimes the times were double compared to the results of one query, sometimes 4 times longer et cetera. So if you're looking for consistency, the best bet is to run the queries one by one, at least for now.
The memory usage of the database daemon seems to stay within reasonable limits, leaving enough headroom for the user application. The CPU usage also stays under control, with the daemon taking ~1-4 percent of a single core when idling. I didn't check the CPU loads when fetching the data, but it's safe to assume that it's 100 % of at least one core is used...
Overall I'm more than satisfied with the performance. The number of points was fairly extreme, at least for my usecases. Typically I use a logging interval of 60 - 120 seconds, so the number of points is reduced by quite a lot.
This performance testing lead to converting my existing home automation system to run on InfluxDB. After I managed to import my old CSV log files to InfluxDB, there's 35 different series of measurements in the database. This adds up to around 10 million measurement points.
With InfluxDB, I can fetch the values of each sensor for any given time range, average them and get the results in a reasonable format with a single query:
SELECT MEAN(value) FROM sensor WHERE time > '2016-03-01' AND time < '2016-03-02' GROUP BY time(5m), id
In the current system, this query takes about 300 milliseconds. Best of all, the result is JSON. This means I can just pass these results directly to the web-based user interface without any processing on the Raspberry Pi.
This of course reduces the load on the Pi dramatically.
If you have any questions you can ping me (@kipe) on resin's gitter channel.
