Take a look at all this great content and let us know what you think in
the breakroom. See you next month!
News from balenaHQ
Supercharge your Dev workflow
The v11 release of the balena CLI comes jam-packed with exciting new features to supercharge your balena workflow. Check out our blog post
here to see how livepush changes the game.
The secret secrets feature
One of the little known secrets of the CLI is that it includes the ability to push projects with secret keys and variables that are only mounted during build. This allows one to use secret info at build time which never makes it down to your devices. You can read more about this feature in our
documentation.
The latest from our blog
Use balenaFin to build your own LoRa Gateway for The Things Network
We’ve taken a look at deploying a gateway for TTN on our blog in the past, but this time we’re going to look at setting one up using the new balenaFin with plug and play hardware! We’ll use the onboard mPCIe slot to interface with a RAK Wireless LoRa module, and use an Adafruit GPS HAT on top to give us location and timing information, then we’ll deploy the software using balenaCloud to allow us to remotely manage and update the gateway.
Monitor your fleet at the edge with Prometheus and Grafana
Properly monitoring a fleet of devices is an evolving art. One of the current leaders in the server world for application and hardware monitoring is Prometheus, both for bare metal and as a first-class citizen in the Kubernetes world. In order to reduce the friction between the edge and the cloud, Matthew McGinn from our team takes a look at monitoring your entire fleet using Prometheus and creating a dashboard to visualize the metrics with Grafana.
Deploy a fleet of environmental sensors with balena & InfluxDB
Last month balena user Alex Markessinis released a project based on balenaSense to manage the temperature and humidity of a data center and upload the data to an external InfluxDB database. Check out this project to find out how to pull information from a fleet of sensor nodes and bring it all together in a central database.
Projects of the month
Every month we like to feature some projects from the community, this month it’s:
Events
IoT Tech Expo Europe | Amsterdam, NL | Jun 19 - 20, 2019 |
Sensors Expo | San Jose, CA, US | Jun 26 - 27, 2019 |
Artificial Intelligence, Robotics & IoT conference | Amsterdam, NL | Jul 16 - 17, 2019 |
Embedded Linux Conference | San Diego, CA, US | Aug 21 - 23, 2019 |
Hackaday Superconference | Pasadena, CA, US | Nov 15 - 17, 2019 |
