05 August 2020 / Last updated: 05 Aug 2020
balena monthly roundup - August 2020
This month we’re excited about partnering with Coral to help developers bring their local AI projects to life. We made a bit of a splash with the Steampunk Geiger Counter project, presented a simple way to start up a LoRa network with Basics Station, and helped users fix those corrupted USB or SD card drives.
From the community, we’re happy to spotlight this project guide on using balenaOS to prototype a GPS tracking system, as well as having a few guests on our IoT Happy Hour to talk shop.
Check out the updates and take care out there!
News from balenaHQ
Partnering with Coral to enable AI at the edge
We’re working together to simplify how edge developers provision, deploy, and manage AI projects. If you have a Coral Dev Board from Google, and some balena skills, go ahead and give our local AI project a try.
The latest from our blog
Check out this steampunk’d Geiger counter
Hardware Hacker Chris is at it again -- adding a steampunk mystique to a Raspberry Pi-powered radiation monitor. Check out the in-depth build guide, watch the video, or try building a simpler version.
That “busted” USB stick or SD card might actually be fixable…
Our Hardware Hackers and Engineers put tons of USB sticks and SD cards to work using Etcher. Sometimes these drives get corrupted and just need a quick fix. Check out the guide to learn more.
Build your own LoRa networks with TTN’s Basics Station and balena
Learn how to command a fleet of sensors using The Things Network’s Basics Station and balena. What will you build next?
Charlie's Tips N Tricks
Get base image details with balena-info
Our base images include the balena-info utility which provides base image information and any warning or deprecation messages.
Simply ssh into a container and run balena-info:
Here's an example of balena-info
Projects of the month
Community project spotlight: SCRobotics uses balenaOS in prototyping
If you’re curious about how to prototype with balena, check out this guide from SCRobotics. They use balenaOS to prototype a GPS tracker, which you can build by following this project.
Build your own IoT security camera network with kerberos.io
On IoT Happy Hour episode 15, we were joined by Cedric Verstraeten. He walked the crew through how to set up kerberos.io with balena and tackled some user Q&A. Check out the episode.
Learn more about how RAK builds LoRa gateways
We had the wonderful opportunity to have Jose Marcellino from RAK on IoT Happy Hour episode 17, where the crew talked about building a LoRa network. Catch up on the episode and don’t forget to like and subscribe.
Job opening: Backend Engineer
We’re looking for a Backend Engineer to help our team to build and maintain the core of balena’s products and services. Get involved with the technical direction for our platform, and design and build its improvements. We’re looking for engineers with a strong interest in building resilient and robust systems, as well as successful products for our users.
Hang out with us
Join us for IoT Happy Hour
We’re postponing our physical events to practice safe social distancing and keep our team safe and healthy. Instead, meet with us virtually during our weekly IoT Happy Hour!
Every Friday at 16:00 UTC, join our live stream to see IoT project builds, discuss hardware and software, talk shop, answer community questions, and more. Join our next session!
